It is currently Tue Jul 17, 2018 7:43 am
PostPosted: Thu Dec 13, 2007 3:38 pm
It's not grounded right. I switch to an Ibanez and all is quiet. The bridge pups were upgraded to Duncan SH6's and I know those aren't usually noisy.
Is there a wiring diagram for my axe? Any other possibilities I should look for?
Thanks in advance!
Peavey 5150 w/Bias mod
ISP Decimator
Electra X260 Invicta
Ibanez RG320DXQM
PostPosted: Fri Dec 14, 2007 1:01 am
Maybe the ground wire to the bridge got disconnected? Does it stop making noise when you touch the strings?
I don't know of a wiring diagram bout it ought to be fairly simple H-H wiring- volume and two tones, right?
Also, it's very probably someone got the color codes wrong. different makers use different codes. The original wiring was probably: white- signal hot; green- signal ground; red- coil tap (if any); silver- shield ground.
Can you provide a pic of the wiring compartment, or take a look and tell what color wires fromt he pickup go where? Meanwhile, look on the Duncan site and see what their wiring color codes are.
