It is currently Wed Sep 19, 2018 2:36 pm
 Post subject: X230 bridge replacement
PostPosted: Wed Jul 30, 2008 1:01 pm
I've heard that electra paul copies had a werid string spacing, if this is true could someone recommend a replacement bridge for my x230?
EDIT: what are the measurements for the machine heads and the string spacing of the bridge?
PostPosted: Thu Jul 31, 2008 7:29 am
A standard Gotoh bridge fit my Workingman X290 just fine. If the string spacing is different you may be able to get a standard metric bridge with un-nothched saddles and have that work by notching the sadles with the spacing you want.
PostPosted: Tue Aug 05, 2008 7:00 am
does anyone know what size tuners would fit best?
PostPosted: Tue Aug 05, 2008 7:34 am
If you are trying for a direct replacement (i.e. no new screw holes) a picture would help. Also stewmac has digrams with dimensions for most of the tuners they sell. I think yours will have a standard (not vintage) 10mm post hole.
PostPosted: Tue Aug 05, 2008 10:10 pm
thnks for you're help
