It is currently Sat Feb 24, 2018 4:05 am
PostPosted: Wed Aug 04, 2010 12:20 am
somehow, I turned the push pull pot knob further than it's supposed to go, something came loose, and the push pull action is now extremely difficult to initiate...it takes a hefty amount of force just to pull out the neck pickup knob to get the 'fat' sound...I am explaining it as good as I can...any idea what actually happened?
PostPosted: Wed Aug 04, 2010 7:28 am
Cant tell you what happened, but I can tell you that is fairely easy to replace the pot. You local music store should have a suitable replacement in stock. They would probably put it in for you (for a fee of course) if your not comfortable doing it yourself.
Paul
PostPosted: Wed Aug 04, 2010 8:35 am
Sounds like you pushed the pot past the stop and jammed it. When you backed it off you may have bent the shaft a bit. Like Robot DR says it is a fairly easy fix. SewMac and all parts are also good sources if you want to do it your self. Just make a little diagram of the wires and the contacts before you start and it is pretty simple.
Users browsing this forum: Google [Bot] and 3 guests
