It is currently Wed Jan 23, 2019 10:18 pm
PostPosted: Fri Apr 26, 2013 5:00 pm
Hello, Great forum. These are great guitars. This Bass is amazing. P-Bass with options. Got it for 120 at a pawn shop.
I need three pieces for an X640.
1. Ring that goes around the tuning peg. between the body and the peg where the string is attached.
2. Main toggle switch end. (pick up selector). Just need the plastic end.
3. A manual or a link to one online.
Thanks
michael.memmi@verizon.net
PostPosted: Fri Apr 26, 2013 5:09 pm
Only link I know of at all on the x640 is right here. Some other members might know of others...
http://www.rivercityamps.com/electrapag ... 216-035904
I would be shocked if a manual could be found online, let alone "in the flesh". Please put up some pictures when you get a moment.
PostPosted: Fri Apr 26, 2013 5:37 pm
I will. Thanks
PostPosted: Mon Apr 29, 2013 4:54 am
1. Ring that goes around the tuning peg. between the body and the peg where the string is attached. 2. Main toggle switch end. (pick up selector). Just need the plastic end.
Thanks
#1 is going to be the hardest piece... I ended up making one for one of mine... it's an odd size, and not likely to find a set of rings anywhere.... let alone 1...
the only option I've seen, was to buy a whole new set of tuners. Gotoh GB1 are closest replacement...
http://www.g-gotoh.com/international/?btp_product=gb1
