It is currently Sat May 25, 2019 8:30 pm
PostPosted: Mon Jan 17, 2011 4:13 pm
On my tele project, I want to lower my action a little, but the neck pup is adjusted to the lowest I can because of the screw length.
I picked up some 3mm, but they must me 3.5mm...
and the pitch is different too...
I picked up some small SAE ones that are slightly bigger and would be easy to tap to the bigger size...
PostPosted: Tue Jan 18, 2011 6:09 am
Yeah, a single coil (in the bridge) has a real hard time keeping up with a humbucker in the neck position. Remember that the strings vibrate more farther away from the bridge, so its a double whammy. I ended up mounting my neck humbucker directly to the wood on 'Buck Owens' and finally got a blend between the two pickups... which means I should have the screws lying around... somewhere... although they're probably not going to be any longer than the ones you have already. I'll take a look around. Maybe a shim in the neck pocket would help... I had to put one in my project before the action was acceptable. Mike.
PostPosted: Tue Jan 18, 2011 10:03 am
sorry, I meant the bridge single coil!
I've got some slightly longer 3.5mm screws coming, so we'll see...
I adjusted it off the end of te srew, so figure I may as well replace them while I take the bridge off to put the springs back in....
PostPosted: Tue Jan 18, 2011 12:15 pm
I used some 4-40 1.25" from Home Depot for my X330. They seemed to do the job just fine. I don't remember them being too tight or being scared of forcing them.
PostPosted: Tue Jan 18, 2011 12:42 pm
Yeah, but they're not metric, so the whole "authentic Japanese Feng shui tone" is ruined! You simply MUST use metric hardware on these guitars...
PostPosted: Tue Jan 18, 2011 3:46 pm
I shall remedy the situation with alacrity!
PostPosted: Tue Jan 18, 2011 4:55 pm
uh oh. I used CTS pots, switchcrafts switches and jack... I'm doomed....
PostPosted: Sat Jan 22, 2011 6:05 am
interesting... I'm gonna grab some... the 40's are used a lot on guns too...
the 3.5mm are too big.
PostPosted: Sat Jan 22, 2011 10:00 am
I remember going through all my pup mounting screws and nothing fit. I ended up bringing the remaining one to the store with me and gettting as close as I could by eye. I was thinking I might have to resort to getting the right height and permanently setting it with nuts on either side of the mounting tab - or one nut and some Krazy glue - but the 4-40's seem to be doing the job.
PostPosted: Sat Feb 05, 2011 4:22 am
that did the trick! i splurged and put 4-40 1" stainless ones in :) pan head slotted. they match the pup pole pieces...
thanks!
PostPosted: Sat Feb 05, 2011 5:33 am
thanks!
Nice! I also recently discovered that some arch top pickguard mounting brackets have the just about correct double bend in them for LP types, Vulcans, etc. I like it when replacement stuff actually works and looks right too!
PostPosted: Sat Feb 05, 2011 7:13 am
Yeah. On the later longneckers the fender replacement ashtray and pup cover fit perfectly...
